Nissan 50C 93 model, power trim fluid
glcoop
I've never checked the fluid. although it still works fine, may be a little slower than years back. Should I and how do you? I didn't see anything in the manual about maintenance on power trim??? Any info greatly appreciated.
TOHATSU GURU
Re: Nissan 50C 93 model, power trim fluid
Raise the engine all the way up and lock it into position. Open the cap, add oil, close cap.
glcoop
I sorry I dumb but what cap? where is the resevoir? is each hydraulic piston it's own resevoir?
TOHATSU GURU
You need to pick up a service manual before you do anything else.
glcoop
I knew you were going to say that. Thanks
