nissan 5 hp no spark HELP!!!!
cboyd
I have a 5 hp nissan 2stroke (ns5b). The motor stuck due to going into the ocean. I had a mechanic break it loose, clean the carb, new plug. He started it and it ran for a min. or two then it stoped due to no spark. He replaced the coil and the brain. Now still no spark. Does anyone have a solution how to get a spark? <br />IT'S not the kill switch. I wish it was that easy!!!!
outboardmech
Re: nissan 5 hp no spark HELP!!!!
check the energizer coil under flywheel
steelespike
Welcome,
You'll get better results if you put this in the Nissan repair section.
pootnic
Welcome,
He would probably get even better results if he answered it over 10 years ago.....:)
