Nissan 40hp won't crank and power trim not working
fisher_girl
We put away the boat last winter the correct way and everything. When we went to take it out this year, we put in a fully charged battery, hooked up all the wiring and when we went to start the motor, there was absolutely nothing. Not a click noise, nothing. Also, the power trim won't work. After changing wires around thinking a couple might of been on the wrong post, we got the bilge pump and fish finder to work but nothing else. What can be wrong? Can anyone help?:confused:
pvanv
Re: Nissan 40hp won't crank and power trim not working
The boat wiring is faulty. You might even have the battery installed backwards (+ instead of -). Double-check all battery connections and any main battery switch. Don't guess. Connecting backwards, for example, can blow up a lot of components.
