Nissan 40hp 1992 trim switch help
cncreteman
New to the forum, I have a great motor, however i had trouble with the trim switch not wanting to lower,, eventually got it down but thinking i might just get another trim switch,Its the older remote handle i believe, the silver box one,, it has the trim switch on the handle with like a place for another switch beside it,,,
Only i cannot find one? I was also thinking or wondering if its possible to put a second trim switch in the boat somewhere in case one malfunctions again,, is this possible and thanks in advance,, Im in Central Pa Harriburg area
Sea Rider
Re: Nissan 40hp 1992 trim switch help
Welcome to the forums,
You could place a second switch, but you would like to have it very close to you to trim engine properly while underway...is the original switch caput ?
Happy Boating
pvanv
Assuming you have an NS40C, right? Year is unimportant, model/serial is everything. You could have a bad switch, bad solenoid, bad pump, low battery, or a wiring problem. Identify the model, get a Factory service manual (from any dealer, including me), and whip out your analog multimeter, then start troubleshooting. Yes, you can add another SPDT-momentary switch anywhere on the boat, or even on the side of the motor cowl. If these tasks sound daunting to you, see your local dealer for assistance.
