Nissan 3.5hp
pscrabber59
Just bought a used Nissan 3.5Ahp motor. Want to change-out the spark plug, water-pump(impeller) before i take it out on the water. PO said it is a air-cool engine but i think it is water-cool but whatever when starting the motor it stars in gear(direct drive?) there is no F-N-R gear. My question is there a impeller in the shaft or behind the prop? I'm used to larger motors when changing the water pump. Thanks for any help/advice.
pvanv
PO was mistaken (or just an idiot). The water pump runs on the prop shaft. [h=5]IMPELLER : 2.5/3.5A 2-STROKE[/h]
Description Impeller only.
Fits:
2.5/3.5A & A2 2-Stroke models
Part #: 309650211M
List Price (MSRP): $18.68
[h=5]NGK BP6HS-10 : FITS 2.5/3.5 2STR[/h]
Description NGK BP6HS-10 Spark Plug
Fits 2.5hp & 3.5hp 2-stroke models
Part #: 970101011M
List Price (MSRP): $3.20
pvanv
Check your owners manual, available online at nissanmarine.com. Spec is 1.0 mm. Thats about 0.040". There is usually a sticker on the motor showing that.
