Nissan 25Hp to 30 Hp
After replacing the old 25 gasket for the new 30 HP carb gasket, perform this simple test to see if your engine will require a + 5? timming advance or not.
1-Remove cowl, place gear in forward.
2-Move throtle to fullest position, check, if white roller stops at middle cam (inside depression) you have 20? timming, if roller stops at fullest left cam you have a 25? timming, check pics. If having 20? advance to 25? by means of A stopper.
3-Loose securing nut, turn screw CCW some milimeters away, throttle fully again, you will see timming mark travelling to 25?, when reaching this position, tight nut against screw. Final check: retain carb pawl with finger to wot position, throttle tiller vigorously back and forth to wot, should hear a slight hammering sound when cam bangs against white roller, re adjust stopper A so to achieve this final position.
4-The extra 5 HP is found at full wot.
Happy Boating
