Re: Nissan 25HP carb gasket
Thanks Sea Rider, in response to your question. The carb gasket was purchased from a Nissan dealer, Pt.# 346-02011-0, and I removed the metal restrictor plate and replaced with the new gasket.
Now I will adjust my carb. Thanks
I have a 14' alum. boat made by Ultra Jon slight V bottom, a new 9.9 X 13" alum prop, the boat was converted from a jon to a bass boat. Added 3/4" P/W for a front deck and the same at the rear. I'm runnng around 5010 to 5070 RPMs WOT.
Also, is the idle adjustment screw on top or on the side so I can set the recommended RPMs.
It looks like from the explosion view of a Nissan Carb that item 4-1-20 is the adjustment screw and item 4-1-18 is the stop screw.
Hello BassNBob, 3 Issues:
1-The air/gas screw is generally on a horizontal position at side of carb, the idle screw is generally at a vertical position, on top of a small pawl, move throttle and see at which screw the throttle pawl rests at, that's the idle screw. Needs to be adjusted to 1000 rpm in neutral or 900 at gear.
2-Your stated wot is a bit low, at wot you should be between 5k and 6 k, near 5.5 would be ideal, with same diam prop go 2 down pitch sizes, can gain + 400 to 500 higher rpm at wot.
3-If needed more power to plane your boat faster with weight you can update to 30 HP, having now the correct gasket without restrictor you are just 50% to 30 HP update. Forget about inssurance as you will still be using a 25 HP cowl. If interested follow complete procedure, if any issue not clear just ask: See if the atached pics on thread matches your engine, if so, proceed, you have green flag!
http://rib.net/forum/showthread.php?t=25933
Will have the extra 5 HP at the end of the throttle as the carb will be reaching top 25? timming mark & 180? butterfly position. If converting to 30 HP don't exceed max top 5,850 rpms at wot.
Happy Boating
