Re: Nissan 25 hp increase to 30 hp restrictor plate?
Thanks for the quick reply. I will sure try the gasket modification as it seems the easiest to do.
Here's some info on why I thought there were different jets for the 25 and the 30.
I went to an authorized Nissan service mechanic and we went through the parts catalog together, for the NSF25A and the NSF30A. They're both listed in the same catalog. Here's a link to the parts catalog that I found on the web:
http://www.nissan-outboard-parts.co...atalog NSF25A-30A (2002) - (002N21050-1).pdf
All of the carburetor parts are the same part numbers...except for the following 4 items: (These are the ones for the 30hp)
Page 10 of the catalog:
3R0-03252-0 - Main Nozzle - 1 per carb
3S9-03275-0 - Main Jet #100 - 1 per carb
3R0-03255-0 - Slow Jet #52 - 1 per carb
Page 12 of the catalog:
3R0-03312-0 - Link Rod - 1 per carb
He also suggested I replace the gaskets since I would be dismantling the carbs.
The gasket is listed as the same for both the 25 & the 30
3R3-03293-0
Thanks again for your reply.
Papafrankc
