I'm having a gradual loss of mojo over the last 6 months of daily use. It starts fine, runs ok, but just doesn't rev up at all like it used to. Very anemic.<br />I have tried just about everything to fix this:<br /> Check prop for dings (ok)<br /> Clean the skiff bottom<br /> Replaced spark plug, (was fouled a bit black)<br /> Replace fuel filter (was ok)<br /> Check fuel flow from tank (Ok)<br /> Disassemble and clean carb (looked fine)<br /> Check needle and sliding barrel for wear (ok)<br /> Check float height (ok)<br /> Check reed valve sealing (ok)<br /> Check for binding in foot, change gear oil (ok)<br /> Check for engine stiffness (ok)<br /> Check intake gasket for leaks (ok)<br /> Disassemble powerhead! <br /> Check ring and bore for glaze (ok)<br />I cant check the ignition timing, as it is electronic on this engine- nothing to adjust!<br />Any ideas or further suggestions? Thanks, LOKI
