Re: nissan 1990 90hp oil injection
The little cylinders are the check valves between the oil pump and carb manifolds. They are designed to keep the oil from leaking back down when the engine is not running. You do not want to bypass the oil injection feature on a Japanese outboard...they almost never fail.
