StarGazerI
- Jul 24, 2011
- 47
I have heard my dad say.. rest is sole, that if you want a job done right you have to do it YOURSELF. I believe in this case he's right on target...LOL So here goes.
1. Take everything yes! everything apart in module form and place each unit into a plastic buckets.
2. I then started to take each Module apart into little pieces starting with Carb then the power head inspecting all barrings rings..etc
3. Soak Carb pieces in sea foam overnight.
4. used CLR and soaked power head base to remove and clean away all or 99% all of water corrosion from all channels as seen in pictures.. I think it came out great! Cleaned and marked position and rings position and put into freezer for re-installation later time
5. Put Carb together with new kits.
6. Re-install equipment and piston back into power-head. Check for binding NONE.
Now awaiting for parts to arrive on Monday 13th.
