Nissan 15 HP NSF15C idle problem
ohiomike
I purchased a Nissan 15 HP electric start tiller steer outboard this past spring from a retailer. I followed the manuals recommendations on starting the motor for the first time, and I followed the break-in instructions precisely. I do not have an authorized Nissan dealership nearby so I did not have it checked prior to running the motor the first time.
The motor starts and idles fine until I slowly increase the speed to approximately 2 mph; the motor then starts doing what i call surging. It acts like I am adjusting the throttle up and down fairly quickly but I am holding it steady. This continues until I increase the throttle enough to reach approximately 3 mph (as shown on my gps). The motor has done this since the very first break-in run in March. I checked the spark plugs after the second break-in run and set the gap on them, but this did not make a difference.
I read the forum threads on the Nissan/Tohatsu motors quite a bit before purchasing this motor so I followed the advice on filling the motor with the correct oil and doing so by using the dip stick as my gauge. I only filled it approximately 3/4 of the way on the dipstick, and I did not use synthetic oil, I also check the oil level prior to using the motor every time. I also run the carb dry after every time it is used, and installed a water separating fuel filter in the fuel line prior to using the motor the first time.
I really like this outboard, except for the surging issue. It frustrates me because I do quite a bit of trolling and use the 2-3 mph speeds when searching for fish in deeper water. I will greatly appreciate any advice that anyone can give me to correct this problem.
pvanv
Re: Nissan 15 HP NSF15C idle problem
You can find the nearest servicing dealer (may be closer than you think) at http://www.nissanmarine.com/search/index.html
Your issue could be a few different things, including a bad prop hub, carb/fuel, mis-adjusted throttle cable, or ignition. There could even be a tiny bit of machining debris that made its way into the carb. Difficult to properly diagnose without being there.
TOHATSU GURU
Does it surge at just one RPM point or at a variety of rpm points?
ohiomike
Thanks for both of the replies. I don't have a tachometer to tell what rpm it is running but it occurs from the time I get to 2 mph all the way to 3.1 mph then it smooths out.
