nicks in bell housing flange.
rebars1
Alpha 1: Getting ready to reinstall the outdrive and was cleaning off the bell housing mating surface when I noticed a few dents/gouges in it. Someone before me must have used a screwdriver to pry the outdrive from the bellhousing. Should I apply some perfect seal to this area before installing the gasket, or should I try to smooth it out with some JB and install the gasket dry?
lilmandavis
Re: nicks in bell housing flange.
i wouldnt use something that could crumble away. i would use the marine 4200 so it comes back off but not jb.
Chris1956
Rebars, I usually use automotive silicone on the OD gasket. It should keep the nicks from leaking.
ted655
Fair the surface with a large file to knock down any raised spots. The low spots will fill with the sealant.
rebars1
OK to use sealant? How much imperfection in the surfaces can the gasket handle installed dry?
DHPMARINE
I probably would use a 2 part epoxy to fill any nicks,let it cure and sand smooth.Also I've used auto body putty,as we have it in the shop.I install the gasket dry.It's really a pain removing gasket sealer the next time you pull the drive.
DHP
ted655
Use Permatex sealant on the part that will be easy to scrape. This will keep the gasket from moving while fitting the parts. Use plain grease on the other side. Next time off, the parts come apart easily.
rebars1
The gasket has a red line/bead of what looks like a sealant around the perimeter. Will the grease affect it?
Don S
I'm with DHP, fix the gouges with some water proof expoxy sand it all smooth and flat. Paint it, Allow the paint to dry completely (Few days) and install the gasket dry.
If you use any sealer, you will have a heII of a time getting it off next time, and probably end up gouging the housing again trying to get the gasket off.
rebars1
What epoxy do you recommend?
Fishermark
I use MarineTex epoxy for anything on the boat - GREAT stuff!
rebars1
I just remembered that I have some Interlux "Watertite" two-part epoxy. It should work OK.
