NGK B8HS -vs- B8HS10? What's the difference??
Dank
Owner's manual says us B8HS10. Has B8HS installed. Is one hotter than the other?
fshng4
Re: NGK B8HS -vs- B8HS10? What's the difference??
Both plugs have the same heat range the difference is in the MAXIMUM PLUG END GAP. The BR8HS-10 is a maximum gap of .040" while the BR8HS has a maximum gap of considerably less than that. If it calls for a BR8HS-10 that is what you want to put in it to achieve the gap you need. The #8 in the plug symbol is the heat rating.
Dank
Thanks guys. The reply is much appreciated!
