I just purchased my first boat. 1989 marathon 22? with a 4.3 Volvo Penta engine. I have the boat in my driveway preparing it for a trip to Lake Erie. I checked the impeller then attached muffs to the water intake on the lower unit and started the engine. I let the engine idle for a few minutes then shut it off. While the engine was running I looked for water being pumped out of the outdrive but didn?t see any. Where does the water exit the drive and should I see it as soon as I start the engine? This was the first time engine has been run since it was winterized last fall. Also I want to lube all the fitting on the outdrive, what kind of greese should I use. Thanks for any advise.
