First could you please tell me the year of my motor with the following information Mercury 115HP Model:1150 Serial:3272796. I placed the motor in a drum of water and to my surprise started right up, I was told that it was setting for about 6 yrs. How can I tell if the water pump is working correctly? I was under the impression that I would see water being sprayed out of the outlet holes near the top of the lower power unit. The only thing I noticed were bubbles coming from the prop at idle, which is as far as I went with it. Also I would like to double check the mixture ratio. I was using 30oz. to 12 gallons of gas. Is this the correct ratio to use of this motor? Is there anything else that should be checked due to the amount of time the boat was sitting? Thanks.
