Re: Newbie question on how to use an inductive timing light
You can not set the throttle to WOT unless the engine is in gear. Sometimes, if I am with another person and the water is calm, I will time the engine at full throttle on the water.
However, these engines can be timed statically while on the trailer and of course, it is safer--no rotating flywheel to bounce your head into. Disconnect the fuel and empty the carb so the engine can not start. Remove and ground all the plugs but hook up the light to the top one. Set the engine to wide open throttle and check the timing while cranking. Correct timing is 28 deg BTDC at cranking and 30 deg while running. If you do not have someone to help turn the key, turn the ignition key to run and at the solenoid jump from the battery connection to the smaller yellow wire terminal (start) On late 90 Forces, the wire may be a different color.
Do not adjust the screw while running or cranking. To do so invites membership into the nine finger club. You stop, make an adjustment then start and check again. Do this until the timing is correct. Turning the screw clockwise closes the distance between the plastic blocks and advances the timing.
