newbie looking for maintenance tips
suasa
So first a little back story before my questions. I have been fishing on and off for the past 15 years but never had a boat. I almost exclusively fly fish so that is a little limiting. Anyway I recently picked up 12 foot aluminum for 80 bucks needed transom corner braces and some paint. Braces have been done and the old paint stripped. I'm going to leave it all aluminum because I am cheap. The boat is rated for 500 lbs and 7.5hp max. So I proceed to Craigslist a 2 HP Johnson for 100 bucks. Only problem is it has been sitting for 5 years. Took me a couple.hours last Sunday to clean the carb and now it runs like a champ. Only problem is there is no water flowing out of it. Then today my boss brings me in a 1970 mercury thunderbolt 7.5hp. Says its mine if I can get it running otherwise he is taking it in for scrap metal. This thing has been sitting for 12 years so I figure getting it running in a couple hours is going to be a challenge. First thing I do is throw a little oil in the cylinders. Then I check for spark. Pulls pretty stiff but its loosening up. Cleaned the pull start as it wasn't retracting properly. I grabbed the fuel tank and drained the 12 year old fuel out. Thank god it was a plastic tank. Throw some new fuel in it and chuck the old girl in my 45 gal from. Pump the primer a few times and it leaks. Uh oh. So I pop the cover and a fuel line to the carb is also leaking. That's not good either. Anyway the bloody thing starts second pull. I could not believe it. Ran great too. Smokey from the oil but runs great. Lots of water flowing out from the water pump. Shifts gears smoothly. What a score!! Anyway. The water slowed right down and now it mostly steams or dribbles water. When full throttle it will have a steady stream but not like before. So now for my questions. Keep in mind this is a free motor and I'm not willing to put.in more.than its worth. Which I figure is a couple hundred bucks. Secondly I and very comfortable working on engines and carbs but I have zero experience working on the leg of a outboard motor.
1. How do I change the engine and leg oil. What type of oil do I need and how much
2. How do I check and clean my water pump and passages.
3. What else should I do to this motor aside from replacing the fuel lines. Keeping in mind it runs like a champ
4. Same question as above but for my 2hp Johnson.
5. I also got a free electric motor keeping a few things in kind which gas motor would you keep. I weigh 300 lbs plus gear and electric I am at almost 400 with no gas motor. I would like to fish with another person in the boat who weighs about 150.
How important is it to keep.under the 500 lb limit in my boat. Will the 7.5 get my boat up and planing with a full load.
Finally what are these motors worth in running condition.
Texasmark
Re: newbie looking for maintenance tips
First I assume you mixed half pint of TC-W3 2 cycle oil with 3 gallons of fuel, or a pt. to 6 gallons.
Second I think it is a good idea to change out the fuel lines, all of them. If nothing else, go to an auto parts store to get hose. Get a new fuel line and primer bulb. Can use fuel line from AP store and Wally World has the squeeze bulb. Ensure you install it with the arrow pointing in the direction of fuel flow......pointing towards the engine.
The lower unit oil is there also in the same dept where you got the bulb. Doesn't take much. A pint container will be plenty. I only use 22 oz on my 90 hp.
To drain the LU oil, the engine needs to be vertical. There are 2 SS screws a little smaller than a dime. One is on the bottom of the lower unit gearbox bulge and the other is up the right side (usually) just above the anti-vent plate...plate just above the prop. Both are identical in external appearance. The drain screw may have a magnet in it to collect metallic particles and having some on there is what it's for. Don't worry.
Remove both screws and drain the oil. It should not be chocolate or cloudy yellowish in appearance indicating water intrusion. Insert the new oil via the drain hole and squeeze tube/pump container pump or whatever to force oil up into the gearbox till it comes out the vent hole. Let a little run out till the BIG bubbles disappear. With the inserting tool still in the drain hole, install the vent screw ensuring that you have the gasket intact. Remove the fill device from the drain hole and as fast as you can (to minimize leakage) install the drain screw ensuring gasket is intact.
That's it.
While you are at WW get some Sea Foam fuel treatment in the auto parts section and run some of that in your fuel...directions on the can. White can with red label. Good stuff. Some folks don't and some folks do....run a fuel supplement. I do and will not change my habits regardless of what others do! Well worth the effort for me.
Good luck,
Mark
alfa
hey suasa... NEW IMPELLER my friend!!! You need to replace that ancient impeller if not the whole water pump down there. Usually there are 4 bolts that you loosen and drop the lower end (where prop is). I don't know this motor but most have a shaft and some type of housing with water impeller in it. You need to get that updated and you may see a stream coming out even in idle, not steam. You got lucky with the motor and that's great... now make sure you don't burn the crap out of it.
As far as weight - I wouldn't exceed the limit, especially if the waters I'm planing on fishing and playing aren't flat as a mirror. You or your buddy gets excited you caught smth and start rolling around, next thing you are capsized... lol
Be smart... it'll get you home each and every time.
Good luck
Texasmark
Good luck
+1. Forgot about an important element; the impeller.
Mark
