Helping my FIL with his boat. He has owned it new since 1990 and never replaced the water pump impeller.
He said last season the water flow was "a trickle" out of the exhaust ports. The ports in question are the 2 that are about midway down the engine, side by side.
Doing some reading on here it seems like water doesn't always come out of those two ports, but according to him it used to, he has been the sole owner since new in 1990.
I just helped him change the water pump impeller today. It actually didn't look bad, the rubber was pretty stiff but it was all there.
Got it back together and it still doesn't flow through. We weren't even getting the trickle he had the last time he used it, there was no water coming out of the 2 exhaust ports today.
1990 Force 90.
We pulled the thermostat housing and the thermostat, and started it up for a couple seconds and got a couple gurgles, but no water even out of the open thermostat hole. There was a ton of water coming out from ports close to where the lower unit gets bolted to, and around the back of the propeller.
This is hooked up with the clamp thingy to the garden hose, not in a bucket. We did not take it above idle.
Where do we go from here?
If it matters the boat hasn't seen water in like 5 years or more at this point, it's been stored in a field for at least that long, possibly 10 or more. He had a shop do the carbs a few years ago, though.
1990 Force 90.
