newbe question
atomb
when the throttle is in neutral should the prop move at all. One would assume not but i'm not sure -mine is moving real slow-is this normal?
dubs283
Re: newbe question
it is possible
you running on muffs or in the water?
could be the drive lube is cold, when it runs through and warms up, prop will probably stop spinning in nuetral
atomb
Re: newbe question
im thinking that from the line of questioning im getting the prop should really not be moving in neutral. can anyone just verify for me? I'm under the impression putting the drive in gear on the muffs is a no no so i try not to do it. is it possible the exhaust moves the prop around ?
Fun Times
Re: newbe question
Some times they might spin with the engine running only B/C of vibration and that is REALLY slow and you can hold it with your hand [SLOW] and it stops and some times with a SS prop on it will do it a little more while on the muffes. Now if you hear any clicking then it would be trying to go in to gear. And if it still spins in the water while in neutral then you have problem with the cabel not aujusted right or it is streched out or you have a problem with the shifting spool inside the lower unit of the drive. Try playing/ moving the cable mounted to the engine and running down behind the engine a little to see if you can get it to stop moving.is it possible the exhaust moves the prop around ? [kind of] also as long as it is idling you can put it in gear to do some testing just try not to keep doing it all the time and you will be fine.
atomb
Re: newbe question
Thanks will do and ill report back
atomb
Re: newbe question
it stopped spining all is right witht the world thanks guys
