Re: New York City Boat Show vs. Transportation Strike
PAKev -<br /><br />Hoboken is a "little bit" of a pain to park in...<br />Frankly, most everywhere you can get the PATH trains is tough, but you might have better luck at Journal Square in Jersey City. You can then go to either Hoboken or Exchange place to pick up the ferry, or if you feel amitious (and the weather is not bad) you can take the PATH to 33rd Street in Manhattan and walk. If you walk, just remember that the crosstown blocks are WAAAAYYY longer than the uptown/downtown blocks, so going from 8th Ave to 12th Ave will be about the same distance as going from 33rd St. to 42nd St. It's still a nice walk, though.<br /><br />Another alternative for parking is to go to the Port Imperial terminal in Weehawken - plenty of parking there, and it's right across from Javits Center. Parking ain't cheap, though.<br /><br /><br />If you take the ferry, check the schedule so that you don't land up sitting on the dock for an hour:<br />
http://www.nywaterway.com/ <br /><br />EDIT: - Save $2:
http://www.nywaterway.com/boatshow.html <br /><br />-------------------------------------<br /><br />P.I.Fred:<br /><br />Check above link to see what the new ferries look like - they're nothing like the old double-enders. <br /> Jet-flea type drive, too - no props (at least on the newest ones).<br /><br />The TUBES? You must be out of Jersey for quite a while!
