whitefish1
- Mar 17, 2011
- 27
When I replaced the exhaust shutter on my '93 Mercruiser 3.0, I removed the upper exhaust tube. I cleaned up the surfaces on the manifold and the tube down to metal (mostly) and put on a new Merc gasket. I reinstalled the upper exhaust tube and torqued to 25 ft/lbs. I started the engine up and I got a small leak at this gasket (more of a weep than an actual leak). I would say its about a teaspoon every couple of minutes at idle. Should I pull and add a small amount of gasket sealer, or will this seal over time?
As an aside, the other thing I noticed is that the new (and old) gasket partially covered the water jacket galleries on both sides of the manifold/upper exhaust tube union. Is this right? Seems weird to me.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
