Hello all glad to be here. I just bought an older boat with a 7.5 Merc (has the 75 label going down the back of the cover). The engine is spotless and has been garage kept (no oil leaks on the floor where it was stored). I didn't notice any oil leaking from the lower end and the compression is fantastic on it. I am assuming there is oil in the lower unit but I could be wrong. The engine hasn't run in about 10 years. I want to make sure I don't damage anything when I try to get her running. Any suggestions? I also want to know if there are any special procedures to changing the lower lube by the prop. If anyone has a manual for it, I'd be willing to pay a few bucks to get it. I can provide SN# after I pick her up and get the title transfered. Also, if there is anything special I should do before trying to kick her over (a little lube in the cylinders?)? Like I said, any info would be appreciated. Thank you.
