Hi all just brought home a 20" bass buggy. The floor is soft and I want to replace flooring and carpet as a winter project. After reading different post and Internet searches I am more confused now then when I started my research. Lots of conflicting information on the web.Here's my latest plan, 3/4" Bcx plywood, top and edges sealed with ploy bottom unsealed as not to trap moisture in then topped with marine carpet glued with marine adhesive. I will use the pontoon 1 week a year at the resort we stay at in Wisconsin it would remain on the lake for that week. The rest of the time it will spend in the pole building only seeing water here in Iowa maybe 1 day a month during the summer. Do you think that combination will hold up for along time based on the usage pattern described or should I splurge on marine grade plywood at $40 more per sheet and use vinyl flooring at more then double the price of carpet. Based on my usage pattern would it makes the most since.
Thanks Don
Thanks Don
