New to OMC and need help identifying what type 5.0L I have
SoILLBoater
Hello Boaters! I am new to the forum but a long time boater. I recently picked up a 19.5ft 1985 Bayliner Cuddy with a 5.0L OMC/Cobra outdrive. I got it on the cheap and needs a few things but I am running into conflicting data when it comes to getting the upper gears for the outdrive. I am not sure how to tell if my OMC is a Ford or Chevy 5.0L which apparently makes a difference in the upper gears for the outdrive. My outdrive is a Model 985271 but when I search for replacement gears there is a 21/17 and a 21/18 option. They don't give these away so I need to ensure that I order the right ones. Just want to make sure that I get this right so any help is truly appreciated. Also, where is the best pricing on these? I am not against used gears either so if someone has some laying around contact me and I will be glad to put them to use. Thanks again!
If your distributor is on front of the engine, it's a Ford. If its at the back of the engine, it's a chevrolet
bruceb58
That is a 1988 drive. Wonder how it got into a 1985 boat. Most 5.0L engines used 21/17 unless it was geared for high altitude. You should be able to pop the top cover and count the gears.
