Hello,
I checked the FAQs, and searched, but I still have questions.
My new to me outboard sounded great when I bought this week, but when I took it to the water, it sputters out and dies when I put it in gear. I bought this can of foam stuff to spray into the air box while in drive like the instructions said. When I did this, the engine was alive and sped up and drove normally for a bit. I let it soak for the 15min like it said, but then when I went to start it up again, I had the same symptoms (ran ok at the fast setting on the throttle while in neutral, but sputtered and drove slowly in gear).
Dealer wants $200 per carb to clean, but says it could be a fuel pump as well or many other things. I can't afford to do this right now and I don't know if I can get to the carbs myself.
Does it sound like a carb issue when it ran pretty good while it was sucking up the foam? Can I try the foam again? Can it be bad gas? (the gas that was in it ran the engine fine at his house and I added about 4 gallons to fill the 6 gallon tank) I am sure I am missing steps that should be done. I don't know where to start.
Thank you for your help.
Joe
Joe
