sphelps
- Nov 16, 2011
- 11,505
I have just purchased an 85 force that I will probably be installing on a 16.5 ft MFG . Questions.
1. Where do I find the model # ? I have looked everywhere.
2. How long should it take for the thermostat to open? The first few times I started with muffs it took about 2 min for the water to start flowing thru the 2 ports in back. I started it earlier today and it seemed like it did not want to open up so I shut it down. The po said the impeller was changed about 2 years ago so I assume it should be replaced.
3. When starting cold it will backfire a couple of times then it starts with no backfire when the motor is warm it fires right up. What would cause this?
4. I really want to learn how to service the motor myself at least the easy stuff. Where can I get a manual?
Thats it for now thanks everyone!
