1995 Suzuki DT40 w/ remote controls.
Installed a new SS prop. Now I lose thrust around 2000 rpms, and then the motor revs. But it is NOT a spun hub-I pulled the prop and it is fine(it is the newer hub-insert design, easily replaceable). I don't hear or feel a jolt or anything when this happens, it just seems to have slipped out of gear... When I slow back down, it will engage again.
I have heard switching to a SS prop can cause this. Why?
I really prefer a SS over aluminum for several reasons, so changing back is not an option for me.
What needs to be adjusted to correct this? I have actually already taken the lower unit apart as of now, but am looking for photos to compare my parts to to determine their condition.
Other info/questions: initial engagement to forward can be a little difficult but a little force will engage the gear. Also, on the throttle arm there is a lot of play, even in neutral without squeezing the button on the underside of the throttle arm. But this "play" does not move the shift linkage at the motor. So is this just play in the control box?
Also, gear oil was coffee black and STIIIINKS!
Thank you fellas. I appreciate any thoughts you have time to post up.
