Re: new rings// compression 60 both cyl.
ryanc - I hate to say it, but not honing your cylinders would certainly explain your poor compression. And also your new rings will never seat properly if it's not done. I seriously reccomend you break down the engine again and do that first.<br />There's a good post about honing here somewhere. I'll find it, since the process is usually inadequatly explained in most manuals. That shiny, glazed finish you saw inside the cylinders will not hold oil, and actually prevents a good seal. The bores must be a very little bit rough.<br /><br />Actually, before you do that:<br />Are you sure water is coming out of those fittings? The ones that are there to recirulate oil back to the intake manifold? (help me a bit here, I'm really not familiar with your engine)<br />If so, you're getting water into the crankcase! Did you obtain a inch-lb reading wrench for those head gasket bolts? I'm thinking water is leaking into the cylinders from the head gasket, and leaking back into the crankcase somehow. Why aren't hoses attached to those fittings? Having them unconnected will allow air to enter the crankcase, leaning out the mixture and causing that sneezing.
