Hi Everyone,
I have a 1991 21' Mariah 2000Z open bow runabout with a mercruiser 7.4/bravo 1 (300HP), and I'm not satisfied with the holeshot/overall performance.
Recently i've been doing more and more wakeboarding, and i waste all of my energy holding on while the boat plows water with the bow in the air and lugs onto plane. I thought that a boat this size w/ this much power shouldn't have this problem...but nonetheless...
The dry weight of this boat is around 2800 pounds, and we usually have about 6 adults on board. We also have a couple hundred pounds of pea gravel under our bow seats to try and keep the bow down.
I'm currently running a Quicksilver Mirage 21P (14 3/4" Diameter??) prop. At WOT I'm reaching about 4150RPM, and get to about 55MPH with the outdrive trimmed as far out as it can go without losing grip. The hull has a 20degree deadrise.
I'm trying to figure out if i should go towards a lower pitch prop with more blades (4 or 5), or a set of trim tabs first. I live in central illinois, so there are no boat dealers around that I can find that will let me demo a prop (a couple of places laughed at me for asking...needless to say i won't be doing business with them!).
I don't have a large budget to work with, so I'd prefer to only buy what i need, and it would be great if whatever solution I choose will help fuel economy (with gas prices already rising!!).
Any insight you have would be greatly appreciated!
Thanks,
Dan
Thanks,
Dan
