New Project! Computer Help Kawasaki 1100 ZXI
SeaDooSam
Hi all!
I just bought a 2000 ZXI 1100. The guy I bought it from stated it ran fine until one time he cranked it a lot and now it won't run. It still cranks over just fine and has 120 psi compression in each cylinder according to my gauge. From what I hear this is likely a computer issue according to research. The igniter module has white speeches on the seal part which certainly don't look normal and it looks rough overall. Any advice?
Thanks in advance!
And is it true these will do almost 70 according to the dreamometer?
QBhoy
I would try another battery first. These and the Polaris are known for dropping voltage below the level that it needs to fire up, when cranking.
