new project boat, need motor suggestions
tashasdaddy
just bought a 1979 18' Bonita Bow rider deep V. nada say weight is 1000lbs, rated for 135 hp. suggestions wanted on what is the best power for this. exterior hull is in good Shape, floor was replaced (bad job) will have to redo floor, foam and probably stringers and transom. will be looking for power while doing restoration.
JB
Re: new project boat, need motor suggestions
Hey, Daddy.<br /><br />What use do you have planned? What is most important to you in an engine?<br /><br />Do you have a budget?
Silvertip
The largest engine you should install is what the boat is rated for (135 HP). The minimum is generally 70% of rated which would be 90 but 100 HP would be a better choice. That would provide acceptable performance with light to moderate loads. If you plan on going out heavy -- there is only choice and thats 135 HP. My suggestion would be looking for a motor in the 100 - 135 HP range. Buy the best and biggest your budget allows.
tashasdaddy
budget, cheap as i can, all round use boat, ski, cruise, fish. i may end up keeping this one. it was rated for a 135 in 79, (we had a 69 Cobia w/ 115 johnny, that was great), if i'm correct, the newer engine have a greater power than the oldies. these boats are the same hulls. some say the Bonita's were 2nds off the Cobia line.
TD_Maker
I think the best Motor for your rig would be a Mid-80's Force 85.<br /><br />Just Kidding
05GlastronSX
no do not buy a force especially a pre-early 90's model made by chrysler. get a reputable motor like merc, jonny-rude, yamaha ect. if you can afford it and find the right deal, only go with 115-135 h.p if possible. you will not regret it...i guarentee...theres no such thing as too much power and you know that weather you need it or not, it will always be there.
tashasdaddy
got my eye on a 115 rude, and 135 merc.
tashasdaddy
traded small bost and 73 50hp rude for 135 merc.
