Re: new motor overheating
OK,did a little more investigating today.Called SEI and San Juan Engineering.SEI said they have had a couple issues with the wear plate in the water pump not sitting completely over the water cavity causing it to aerate at higher rpm's.Also issues with the impellers slipping on the hubs.The guy said it shouldn't be the slipping impeller,as they are using OEM now.San Juan said the engine driven seawater pump is not required and that they have hundreds of these systems in use(with the new dry joint exhaust) around the world including warmer climates like Florida and such,with no problems.Was gonna start by pulling the lower unit and checking it out but,when I got the boat home tonight and flushed the motor I kinda checked things out.Idling on muffs at 175deg.,coolant lines felt hot by hand(feels real hot after about 5 secs or so)but,the risers feel cool.The water exiting the transom felt luke warm at best.I MIGHT take a shower at this temp on a ROASTING summer day.Pee warm MAYBE.After raising the rpm's to arount 1600,the water exiting the transom warmed to about comfy shower temp and temp guage was maybe 5 deg cooler.At idle,top of heat exchanger is hot,like the coolant lines but,the bottom and ends are COLD,like you want your beer cold.I'm not understanding.Didn't check the exchanger at higher r's(damn it)I'll do that tomorrow.With my coolant at 175,shouldnt my exchanger be hot all over?coolant lines feel hot,outlet lines feel very much cool.
