Re: New Motor Break-in 20hp 4-stroke
Its best to follow the guidlines of the maker............for sure change the break in oil and filter to get the metal out............never race the engine in any way in neutral nor let it idle for long periods............I don't think constant speeds will hurt anything ........just keep it somewhat under full throttle and make the engine pull............down throttle slowly unless you have no choice..............all in all put it to the test at different levels of power to know you have a good engine..........You can change the lower unit oil to be sure there is no water and check the plug to get any metal off................The more you know about your engine the better off you will be in the long or short run............ Always use good quality clean fuel.........Always watch for oil or fuel seepage and check for loose screws , bolts, fittings all over............. good luck...........
