New MercMonitor Install??
boatman1011
I just hooked up a MercMonitor Data Level 2 kit to a new 250 Pro XS and have gone through and set up most everything with the boat/motor. The only thing that isn't working correctly is the trim gauge. I noticed that the trim sender on the engine is the analog sender, (brown w/ white stripe) so i'm not totally supprised that it isn't working. My question is do I need to replace the sender with a digital sender or is there a location to re-route my analog sender threw the PCM on the engine to send out a digital signal to the MercMonitor? :confused:
Fun Times
Re: New MercMonitor Install??
The way to it right is to order and install a new digital sender if you don't already have it.
Starting with post #103 in the link below, follow Ring leader's post as he goes over the trim system. Also the first photo of post 112 is the digital signal trim sender part number 859187A1. Post 117 may be important for you as well.
http://forums.iboats.com/mercury-ma...l-smartcraft-system-269999-5.html#post2417617
Hope this helps, Good luck.:)
