New Merc.200 EFI Problems
maxsixshooter
First day in water lost power, dealer <br />had to change the fuel injecters. Now motor gives off excesive smoke when first started, also heavy vibration at 2000 RPM's. First boat and motor for me. Any and all opinions appreciated<br /> Thank You<br /> Lee
MERCMAN
Re: New Merc.200 EFI Problems
Is this a Opti-Max or a EFI 200. If it is a Opti-Max there was a recall to replace the direct injectors and also the fuel is not to be mixed with oil that can cause engine to smoke. If it is 2.5 EFI why in the world did they replace all of the injectors that's a first.
maxsixshooter
Mercman,motor is a 200 EFI. Believe the problem to be engine is dumping to much oil. Having it checked tomorrow.
Frank
I have twin Merc 225 EFI's and they always smoke a lot when first started. When warmed up it stops.
