New Member (Parts)
Hello, I am new to the forum but not to two strokes. I have built/restored 3 vintage 2 stroke bikes. I am currently working to repair a 1982 25 horse Murcury outboard Motor. It will run but at the present it has fuel problems.
Question is, where is the best place to order the parts needed for the carb. The sites I have been to says no longer avabale. Just like with the vintage bikes I am sure there are places to get aftermarket parts etc;.
I have not yet read all of the info on this site. It looks to be a great source of imfo. Thanks for all and any help. Kawasakitriples on the Bayou.
Mi duckdown
Re: New Member (Parts)
Kawasaki.
A Good merc dealer has/Should, have complete,rebuild kits for that carb. or can order complete rebuild kits for that carb. also Mercury marine.com
the only things that are N/A is the float needle.?? go figure.
You must have your serial Number to order anything.
Thanks for the quick reply's. I went to boats.net, no go for the gaskets etc;. I like to work on these old motors the hardest part is sometimes finding what you need. I am lazy when it comes to going on the road and looking for parts. I much perfer to order and pick it up at the front door. I will look at the above mentioned site and or keep looking. Thanks for the help.
metalwizard
Welcome to the forum. I can't answer your question. but you gotta love a two stroke.
I just sold an 86 yamaha RZ350.. had it for years. (along with other two strokers..)
Good luck finding what you need!
No, I promise it is not. I am not a computer expert, but I do try. The Mercury 25 HP is a 1982 #6153235. I do not see that on the above site. Looking for the gaskets for the bowl, and fuel pump etc;.
I am not into this kind of jokes. Thanks for the help.
Mi duckdown
Kawaski.
sorry. I can't beleive you can't find the kit or parts. Google MercuryMarine.com
Is a good source, hard to navigate.
I Go to my Merc /Parts dealer and can buy damn near anything I want, If it still available.
What do you Need?
I rebuild alot of single carb motors for friends never had a problem buying kits from MY Merc dealer.?? from 1963 till 2000
Just for starters I know I need the bowl gasket. I may have to rebuild the fuel pump but not sure at this point. 1982 Merc 25 HP.
Different motor, 1995 25 HP Murc. I am looking for just the fuel air mix screw. I did find the kit for this motor, not just the screw.
Mi duckdown
You need the serial Number off the motor to buy anything, to get the right parts.
Mi duckdown
When you buy a carb kit. BUY THE THE ONE THAT REBUILDS THE CARB AND FUEL PUMP. DONE
Faztbullet
The carb gasket kit for this model does not have bowl gasket in kit you have to order a repair kit it get it. Just order the aftermarket from iBoats part # 18-7212 as it has ALL gaskets and $30 cheaper than Merc...
mjc3834merc
Mi duckdown
Don't get it. I just rebuilt a 25hp 1983 last year. Walk into the merc parts dept. and bought it. I do believe the bowl gasket came with it. 3 different kits. one comes with just carb gaskets, one with carb gaskets and fuel pump kit, one with both and all the plugs spring etc.
Thanks, I intend to do a little work on it this week. I will call them to make sure I am ordering the correct parts.
Does anyone here find that the jets/needles etc are just as good as OEM?
Mi duckdown
Kawasaki. who are you calling?
i'm going to my OEM merc parts dealer tommorow to buy some things.
I have got your serial number in my wallet.I will check out your request on the carb kit/kits. Available or not.
Not sure yet. I want to do a little more trouble shooting before moving to ordering parts. Thanks, I will look at the post tomorrow. Kawtrip on the Bayou.
What u found out Podna??? I intend to do a little trouble shooting today.
