I was just hammering the old shift lever pin out (after heating for a bit) and all of a sudden there is an oil substance dripping out a small hole on the upper section of the lower unit.
Can someone tell me about what this may be?
I am assuming that whatever it is was caused by the 8 or so whacks I did with the sledge to get the shift lever pin out.
Maybe I free'ed up a weep hole?? But what would weep here?
Oil Dripping...
Man was the shift lever pin stuck...almost welded in there.
Good photo to show why you should definitely lube all zirk fittings you find.
Oil Dripping...
