New Johnson owner
Moboter
Hello all,
I recently purchased a newer boat with a 2001 Johnson 90hp motor. The model number is j90plsi. I was looking at parts on this site and not sure if this is a loop or a cross or neither? They don't make it easy to order parts too many options. Also when I start the motor and push in the key to choke the motor shouldn't I hear the choke click or does this model have a different style of choke every boat I've been on before you can hear the choke click. Sorry new boat owner any help would be appreciated.
Re: New Johnson owner
Motor is loop charged.-----Take the cover off and listen for the primer to click.
boobie
When you're starting it hold the key in until it fires. A lot of misinformation out there about starting especially when cold.
Chris1956
You may look up parts by the model number on the crowleymarine web site
boobie
You can also do the same thing at shop.evinrude.com.
Roberthill
Make sure you turn key to "on" position then push in and you should hear a click . If you push key in and then turn to on and then to start you won't get a click .
