Re: new impellor....no water!?#%$&
Chris.... If you're speaking of installing lockwashers between the water pump housing and the plate, you've got the water pump drawing air, in which case, it will never pump water.<br /><br />Drop the lower unit and start over. Remove and clean the water pump housing, plate etc if needed. Hold the water pump housing in your left hand (have a slight bit of grease lubricating the cup). With your right hand, insert the impeller into the cup with a counter clockwise spinning motion. Arrange the impeller in the cup so that the driveshaft hole is aligned and that the keyway is where you want it.<br /><br />If there's a gasket under the water pump plate, use gasket sealer on the gasket (sealers defined below). If no gasket exists, use Sealer 1000 or its equivalent (also defined below). Now, have the "O" Ring installed on the bottom of the water pump housing and coat it with the Sealer 1000 or equivalent.<br /><br />Slide the water pump housing/impeller assy "straight down" the driveshaft and carefully onto the woodruff impeller key that is in/on the driveshaft. Be carefull that you do not disturb the sealing "O" Ring on the pump housing. Install and tighten the pump housing retaining bolts.<br /><br />Now, check the measurment from the bottom of the engine's exhaust housing (the long housing between the powerhead and the lower unit) to the bottom of the water tube, then check that measurement against the grommet area of the water pump housing. This is to check to see if you accidently missed the water tube, had it slightly off center when installing the lower unit previously.... and shoved/bent the water tube upwards. If this happened, you'll need to get that tube back down to where it belongs somehow.<br /><br />If all is well to this point, carefully install the lower unit, making absolutely sure that the water tube is inserted into the proper water pump area. That should do it. Now, about the sealers, probably more than you want to know but.....<br /><br />(Gasket Sealers)<br />(Usually available at any reliable automotive parts type store)<br />(J. Reeves)<br /><br />Do Not use any type of sealer on outboard carburetor or intake manifold gaskets as this would cause blockage of various fuel/air passageways. Also, there are new type gaskets, including head gaskets, which are used through out the engines that are coated with a substance that gives a shinny appearance to them. These gaskets are coated with a self sealer and are to be installed as is.... no sealers! Older style head and fuel related gaskets that are not coated with this substance are to be simply coated with oil.... nothing else.<br /> <br />All other gaskets (hopefully I've not overlooked anything above) should be coated with Gasket Sealer (the type that comes in a can that has a small brush in its screw off cap). This also pertains to some water pump installations that use a gasket between the plate and the lower unit housing.<br /> <br />Marprox Sealer 1000 or OMC Adhesive or Boat Armor Sealer 1000 (same substance) should be used on any metal to metal or metal to plastic surface (such as impeller hsg to plate) to eliminate air leaks. It should also be used on the Spaghetti tubing that is used on many powerhead crankcase halves, lower unit skegs, etc. I have found that this substance works quite well on various "O" Rings such as what are found on lower unit carrier and upper driveshaft bearing housings (Note that this substance is obviously not to be used on all "O" Rings).<br /> <br />DO NOT use any sealer on the large "O" Rings that are used on the upper and lower crankcase heads (The housing/heads that slide over the top and bottom of the crankshaft). On those "O" Rings, use only a coating of grease.<br /> <br />The exception of surface to surface contacts pertains to the later model matching crankcase (block) halves (which does not incorporate spaghetti tubing) which call for "Gel-Seal", or any other surface that calls for Gel-Seal. This substance seals in the absense of air, and if called for, must be used. One other form of Gel Seal that can be substituted is "Loctite #518". Nothing else that I know of will do!<br /><br />I advise against using silicone or permatex on a outboard engine. It simply will not function properly. The exception to this (as per OMC's recommendation), is to use the black Permatex (heavily) on the gasket 306242 which seperates the inner exhaust tube from the exhaust housing on the 1959 35hp and 1960 to 1970 40hp OMC outboards.
