Re: New Impellar, Still over-heating
When you install the new pump kit, with the impeller on the drive shaft, spray it down with mild soap and water (NOT GREASE OR OIL)and turn the shaft clockwise ( the same way the engine turns ) and push the pump housing down over it . Then if your not close to a body of water , take the prop of and run it in the biggest bucket or can you got (try to get the water up to 1-2" below the exhaust relief holes.Then let us know. Good luck.
