'96 88 HP johnson special
Put new head gasket on starboard side as bottom plug was getting salt deposits on it. Torqued all bolts to 18-20 pounds and ran on muffs in driveway. Had a slight drip on the very bottom, torqued bottom bolts a little more(torque wrench read 22 pounds when drip stopped.) and drip stopped. Just ran boat in the ocean for about 15 miles, stopped once to check under cowl and all looked good. When I got home I saw salt deposits all around the outside of the gasket. Not alot but it was consistent all around. Checked plugs and they were great looking, a little bit of oil on them but no salt and they had not been washed by seawater. I know the gaskets need to be retorqued after a little break in, could that be the cause of my salt on the outside? I have retorqued and cleaned all the salt off and will run again on the week end to see if i solved it. Anyone else have this issue?
