Greenacarina
- Jul 12, 2017
- 8
Hi everyone!
Brand new boat owner here with a not-so-new boat that i am trying to revive.
I am a long time car guy, so mechanical things and engines are familiar territory.
I have a 17 ft tri hull with a mercruiser 221hp inboard. I have been told it's a ford 302 but my little bit of internet research says maybe ford 351? I am not a "ford guy" so this, too, is somewhat new territory.
Here are the clues to this mystery so far.....
Engine froze and popped out 2 feeeze plugs. Couldn't see any cracks in the block.
Lower thermostat housing is cracked and appears someone tried to jb weld it...unsuccessfully.
Oil looks good and clean...not "new" but close.
Today i hooked up a battery, pulled the spark plugs and did a compression test.
Everything read about 95 psi...which isn't good...but is also very weirdly consistent...so i bought a new compression gauge just in case.
Here are my first few questions -
Do i have options (better or worse) for my thermostat housing?? I saw one used on ebay for $45
If this engine is "toast"...am i better off rebuilding it, or putting something newer and more modern in there?
Any upgrades for reliability i should consider?
I'm sure i've left some info out...but i am here to learn and put together a reliable boat.
Thanks in advance!
Chris
Thanks in advance!
Chris
