RC_DynaTrak
- Sep 27, 2020
- 6
Hey folks - long-time fisherman, 1st-time bass boat owner.
I was bequeathed a 1985 Ebbtide Dynatrak with a 90 hp Yamaha 2-stroke.
Previous owner was my best friend's father (and a 2nd father to me) who recently passed away. He took very good care of this boat - especially the engine - but 30+ years of use, wiring & parts fixes, etc. took a toll and it was in need of some updating and TLC to get it back on the water. I've finally started in earnest (mostly re-wiring), but even after pretty thorough research I'm a little puzzled by the livewell plumbing situation.
The old pump & hoses were tossed before I had a chance to decipher the original plumbing. Hopefully the attached pictures and captions are adequate here.
There's two thru-hull fittings in rear of boat/bilge:
- one is a bulkhead fitting with 3/4 barb connection on the inside (Right now there's a drain hose connected to this, running from a cooler hatch in front of the console).
- The other drain hole - lowest and centered - has a brass bushing & 1" snap-handle drain plug.
On the back of the livewell there's two holes up top and a drain outlet at the bottom:
- A 3/4" ID hose goes into the top-most hole and connects to a perf'd horizontal tube with a little shutoff valve. I assume this is for fill & aeration.
- Overflow hole (I assume) is 1-1/8", slightly lower than the fill hole.
- Bottom drain outlet is a 3/4" OD barb. Drain hole is 1/2" ID on the inside with a snap plug for it, no threads or anything for a screen/strainer.
_Sooo...my question, I guess, is how would you plumb this livewell?
- I feel like the barbed thru-hull fitting in the bilge should probably be a raw water intake, no? Except there's no threaded fitting on the outside for a strainer to screw onto (just the bulkhead fitting). Would you replace it with a different fitting to feed a water intake? Somehow I don't think the cooler drain needs to be connected to a thru-hull port. Can't it just trickle into the bilge to be pumped out?
- Overflow of livewell: would it just slosh into the bilge (via a short hose run) to be pumped out? or piped to...where? I have one thru-hull above the waterline in the rear for the bilge discharge.
- Can I do a full recirc / aerate / exchange / pumpout with the existing holes in the well and hull?
Thanks in advance for your advice and assistance. This is a labor of love for me and will mean a lot to the previous owner's family.
