New Guy, bought a SoonerCraft and a Johnson
303sooner
So i bough a 70s "SoonerCraft_tri hull" My first boat, didn't know diddly squat about boats or boat motors. A months later i purchased a 1961- V4SL-13 Johnson Seahorse 75HP motor.
The boat ended up having rotten decking and stringers. I pulled out the rotten wood and glassed all new wood in.
I have a good friend who is a boat and jetski mechanic, he is helping me with this project. He doesn't know too much about the old school outboards but has helped me tons with the rotten wood replacement and motor installation.
I'm an autobody and RV technician by trade, but have no boat experience.
My problem now is when i run the 75HP Johnson, the port side head gets hot to the touch within 60 seconds or so, while the starboard head stays cool to touch for minutes and slowly comes up to temp, both sides have spark and fuel.
My buddy tells me that this is not normal and i should be able to touch both heads with no problem.
We also found a water leak coming from the top of the same hot head head gasket.
At this point i pulled the head to check for cylinder wall damage, cylinder walls look good, plugs look good too.
My Boat mechanic buddy has a hunch that it may be the port side carb running too lean and overheating the port heads/
So that's my story. Sorry if i posted in the wrong thread.
Would be nice to see if anyone has some input
Ill post some pics when i get to my 3rd post
jbcurt00
Moved to the Johnson/Evinrude outboard forum.
Ask motor questions here.
If you have questions about the rebuilding the boat, start a new topic back over in the resto forum where you left this originally
Good luck w your project
