New guy 1981 115 hard to start and runs poorly.
Finishizer
Hey everybody, new guy here. I just bought a 1981 seaswirl with a johnson 115 seahorse two stroke. It has been sitting for two years. The motor was stored without the gas being run out, so I have been trying to get the the bugs worked out. It ran great the last time the previous owner took it out (again two years ago) he is a friend of mine and i trust what he tells me. He replaced the plugs, impeller and gear oil right before I bought it. I've had it out twice. Super hard to start. the first time the plugs fouled burning off the old crap. I pulled the plugs and cleaned them then the boat ran fine. This last weekend, again, took me 15 Minutes to get it started. Then it kept dying at idle. It got us where we needed to go but was not happy. Can anyone give me some pointers? I know a little about two strokes since this is my second one, but not enough. Any help would be greatly appreciated. Sorry for the long-winded first post.
flyingscott
Those carbs need to be cleaned and hopefully you are using fresh gas at a 50-1 mix.
Finishizer
Yessir. I've gone through a tank and a half of chevron 91 octane at 50:1 mix. your not the first to say clean the carbs. How do I clean the carbs would be my next question.
interalian
Cleaning requires complete teardown and installation of rebuilt kits. There are welch plugs covering the idle passages that need to be popped out to inspect/clean the orifices underneath. As you say it was stored for 2 years with old fuel, the best way forward is to get a jet wrench and pull the jets out as well as soak/blast all passages with carb cleaner and compressed air. Sounds complicated, but it's surprisingly simple. To make it easier for the re-start, just pop the throttle rods out without distrubing any of the setup screws. That way your carb linkages should be close to OK when you put it all back together.
Not sure if your 81 has primer or choke flaps (primer is a nicer system). Hard starting could also be a primer/choke that's not working properly.
Finishizer
Ok, sounds complicated for sure. But I'm reasonably mechanically inclined. I've already ordered the rebuild kit. As far as a jet wrench. I'm guessing that's a specialized tool? Is there something else I can use? As far as choke flaps or primer flaps? I'm absolutely clueless. It has a primer bulb on the fuel line.
emdsapmgr
Are you working from a genuine factory service manual? The illustrations in it are extremely helpful.. Check out this website: outboardbooks.com
Finishizer
no i am not. just jumped in with both feet. i'm using forums and talking to friends with boats. i'll order up a manual today.
ondarvr
91 octane fuel is of no value in this motor, save your money and get 87.
interalian
I made my own jet wrench - middle tool in the pic below. Found an old #1 Phillips screwdriver with the right shaft OD, then ground it to a flat and square tip. The flats need to engage the jet snug and their faces need to be parallel.
Finishizer
Ok, got a little update. Today I rebuilt the carburetors, and replaced the spark plugs. I have been reading alot. Anything I can find. I think I was having a hard time starting it because of operator error. Lol I read something somewhere that gave the whole startup sequence. I think I was flooding the motor so that's why it was hard to start. Today it fired up after 3 3 second cranks and ran well. (in the driveway) I did find a hole underneath those little plugs you gotta use a punch to get out. Someone got a little crazy with the hammer. Thank you all for the advice. I'm exited to take it out next weekend and have that (piece of mind)
