weider1717
- Sep 2, 2008
- 315
Hey guys you might remember awhile back I had talked about needing a new tank for my ski boat...well I contacted the maker of the original tank and $500 bucks later I had a perfect match to the original.
the only difference is the pickup tube they sent me doesn't fit the copper tubing that attaches to the pickup tube
they sent one with a barbed end for sliding a tube up on it looks like to me..but my boat has a cut off valve attached to tubing with a flanged end that tightens down on it.
so my question to you is should I buy a fitting to make the new pickup tube work or should i use my old pickup tube? I took the old one off the original tank and ran hot water through it for awhile..if you shake it u can here what I believe is a check valve inside I can see it with a flashlight and see the filter screen on the little valve in there...
the new one has a ball looking check valve on the fitting that DOESN'T work on my boat...so if I use the new pickup tube i would have to by some sort of anti syphion check valve...
here are the pics the old one is all aluminum! the new one is plastic like on the tube part..which should i use? think the old one being cleaned up will be fine? this is off a 84 boat.
thanks and here are the pics again old one is the all aluminum one.
