Tommyfmu
- Sep 16, 2009
- 63
So my port Crusader 350XL dropped its oil 2 weeks into the bilge until it stopped while underway. Next week I filled it with oil and it idled fine, but when I powered up again within 30 seconds it dropped all its oil into the bilge, so I shut it down immediately.
Found out that the leak was coming from the remote oil filter adaptor way underneath. Fine, that can be fixed, or removed and the oil filter put on the engine directly.
I've been told, by two difference mechanics now, that I've spun the bearings due to the oil pressure drop, and at a minimum the engine needs to be pulled and repaired, or better yet put in a remanufactured one.
Does this sound true? She starts right up no problem, idles fine, and I don't hear any sounds different than my stbd engine even when revved up; i.e. no metal on metal, no hesitation (carbs were just rebuilt). I have not fixed the leak and tried revving it upwards of 3k while underway ; if I rev it up while idled I can see the oil pressure drop a bit telling me its dropping some oil into the bilge.
I trust both of them but was just wondering if that's happened to anyone else and you just fixed the leak and it lasted without any problem. Thanks, Tom.
