Re: New Engine Breakin
Hello. Couldn't agree more. Although with today's improved machining (ie: improved cylinder bore finish), break-in is less critical than previously, it's still a good idea. The cam, as stated, is most vulnerable at this time. The rpm's must be up as stated to ensure a good amount of splash to the cam lobe and lifter. A cam break-in compound applied during assembly, a primed oil pump, carb bowls topped with fuel (if applicable) and the distributor lined up with certainty on #1 (not 180 out), followed by the next 20 minutes with a non-synthetic oil with sulfer are critical. Then change to oil and filter of choice. Unlike drag and street engines, these marine duty applications live their whole lives under load, so we must be even more compulsive about their assebly and maintenance! Whew!
