Re: New coupler says "Top Holes Not For MTG"
The through-bolt method also prevents side loading on the tongue which would occur if you used separate bolts to bolt each side of the coupler. You likely can't reach the back holes with separate bolts but I have seen this done and almost always the tongue and coupler are bowed outward due to the stress.
I am trying to visualize why this would be if the proper size coupler is used on the tongue.
I have seen the use of long bolts going from one side to the other over torqued and collapsing the coupler and tongue.
Can't do that by using seperate bolt for each hole.
That being said, I use seperate bolts on all holes other than the up front holes.
There I drilled the holes out a bit bigger to match the max. bolt size that would go thru the safety chain links. I then used one stud threaded from each end, enough for two nuts and washers sandwiching the tongue and coupler on each side. (One nut inside the tongue and another outside the coupler.) The last safety chain links are on that stud inside the tongue. They are not wrenched down but are floating on the stud with washers in between the chains to fill the remaining space on the stud.
Over kill I know, but look at how your safety chains are attached to the tongue. On mine the last link had a tongue bolt thru it but the next link prevented the last link from laying flat to the coupler surface. So when the bolt is torqued down the chainlink is tilted, which is putting the wrong load on the bolt. Like the link is bending the bolt head off. Un acceptable for me.
